Krion Posted May 11, 2020 Share Posted May 11, 2020 Hi, From the sidefx docs I stole this code: desktop = hou.ui.curDesktop() viewer = desktop.paneTabOfType(hou.paneTabType.SceneViewer) # Copy the viewer's current flipbook settings flipbook_options = viewer.flipbookSettings().stash() # Change the settings however you need # (for example, set the frame range and output filename) parmi = hou.parm("/obj/comments/addtoflipexport") flipbook_options.frameRange( (1, 5) ) flipbook_options.output("$HIP/flipjes/flipbook_FRM=`padzero(4, $F)`.jpg") # Generate the flipbook using the modified settings viewer.flipbook(viewer.curViewport(), flipbook_options) I did change the normal $F from my original filename to `padzero(4, $F)`, but it still only outputs one frame. How do I make it update along with the frame number while the scene is generating the flipbook? Thanks in advance. python flipbook.hipnc Quote Link to comment Share on other sites More sharing options...
alex333d Posted May 22, 2020 Share Posted May 22, 2020 (edited) You can use this code if you want, it will create small UI with name of flipbook and you can manually set whatever frames do you need. also it will create two folder: 1 jpg sequence, 2 hip file Important! You have to have in your project folder "flip" (it will save your flipbooks inside this folder) and the name of hip should containe version, as example "test007_sc4546_v003_explosion") so flipbook will take this name "explosion" import toolutils import hou import os import sys import re from datetime import datetime ### frame range ### start = hou.expandString('$FSTART') end = hou.expandString('$FEND') ### ui ### text_to_search = hou.expandString('$HIPNAME') pattern = re.compile(r'[v](\d{3})[_](\w*)') matches = pattern.finditer(str(text_to_search)) for match in matches: def_name = str(match.group(2)) print (match.group(2)) gamma = 0.7 #def_name = "flipbook" list = ["Name", "Fstart", "Fend", "Gamma"] list2 = [def_name, str(start), str(end), str(gamma)] read = hou.ui.readMultiInput("Flipbook settings", list, initial_contents = list2) range_start = (read[1][1]) range_end = (read[1][2]) gamma_in = (read[1][3]) ### folders ### date = datetime.now().strftime('%d.%m.%Y') job_folder = hou.expandString('$JOB') hip_name = hou.expandString('$HIPNAME') flipbook_folder = job_folder+"/flip" data_folder = flipbook_folder+"/"+date version_folder = data_folder + "/v0" if not os.path.isdir(data_folder): os.mkdir(data_folder) filelist = [] os.path.isdir(flipbook_folder) find = version_folder.rfind('/') cut_path2 = version_folder[:find] #print cut_path2 for folder in os.listdir(cut_path2): pattern = re.compile("^v(\d*)$") result = pattern.match(folder) if result is not None: num = int(result.group(1)) filelist.append(num) mx=0 if len(filelist)!=0: mx = max(filelist) version = mx+1 version_folder = data_folder + "/v" + str(version) jpg_folder = version_folder+"/jpg" hip_folder = version_folder+"/hip" file_name = str(jpg_folder)+"/"+(read[1][0])+".$F4.jpg" os.mkdir(version_folder) os.mkdir(jpg_folder) os.mkdir(hip_folder) hip_name_save = hip_folder+"/"+hip_name+".hip" hou.hipFile.save(hip_name_save) ##### Copy the viewer's current flipbook settings cur_desktop = hou.ui.curDesktop() scene = cur_desktop.paneTabOfType(hou.paneTabType.SceneViewer) flipbook_options = scene.flipbookSettings().stash() flipbook_options.frameRange((int(range_start),int(range_end))) flipbook_options.output(file_name) flipbook_options.gamma(float(gamma_in)) scene.flipbook(scene.curViewport(), flipbook_options) #newPath = file_name.replace('/', os.sep) #hou.ui.displayMessage(jpg_folder) #os.startfile(jpg_folder) Edited June 23, 2020 by alex333d 1 Quote Link to comment Share on other sites More sharing options...
Krion Posted May 22, 2020 Author Share Posted May 22, 2020 Thanks for sharing alex333d, I will look at the code and try it out. Quote Link to comment Share on other sites More sharing options...
bunker Posted June 3, 2020 Share Posted June 3, 2020 $F4 gets evaluated inside the python script so it's "baked" into the code, there's probably a cleaner way, but this works: flipbookpath = "/tmp/flipbook/mysim" flipbook_options.output(flipbookpath+".$"+"F4.jpg") Quote Link to comment Share on other sites More sharing options...
vinyvince Posted June 21, 2020 Share Posted June 21, 2020 On 5/22/2020 at 3:10 PM, alex333d said: You can use this code if you want, it will create small UI with name of flipbook and you can manually set whatever frames do you need. also it will create two folder: 1 jpg sequence, 2 hip file Important! You have to have in your project folder "flip" (it will save your flipbooks inside this folder) and the name of hip should containe version, as example import toolutils import hou import os import sys import re from datetime import datetime ### frame range ### start = hou.expandString('$FSTART') end = hou.expandString('$FEND') ### ui ### text_to_search = hou.expandString('$HIPNAME') pattern = re.compile(r'[v](\d{3})[_](\w*)') matches = pattern.finditer(str(text_to_search)) for match in matches: def_name = str(match.group(2)) print (match.group(2)) gamma = 0.7 #def_name = "flipbook" list = ["Name", "Fstart", "Fend", "Gamma"] list2 = [def_name, str(start), str(end), str(gamma)] read = hou.ui.readMultiInput("Flipbook settings", list, initial_contents = list2) range_start = (read[1][1]) range_end = (read[1][2]) gamma_in = (read[1][3]) ### folders ### date = datetime.now().strftime('%d.%m.%Y') job_folder = hou.expandString('$JOB') hip_name = hou.expandString('$HIPNAME') flipbook_folder = job_folder+"/flip" data_folder = flipbook_folder+"/"+date version_folder = data_folder + "/v0" if not os.path.isdir(data_folder): os.mkdir(data_folder) filelist = [] os.path.isdir(flipbook_folder) find = version_folder.rfind('/') cut_path2 = version_folder[:find] #print cut_path2 for folder in os.listdir(cut_path2): pattern = re.compile("^v(\d*)$") result = pattern.match(folder) if result is not None: num = int(result.group(1)) filelist.append(num) mx=0 if len(filelist)!=0: mx = max(filelist) version = mx+1 version_folder = data_folder + "/v" + str(version) jpg_folder = version_folder+"/jpg" hip_folder = version_folder+"/hip" file_name = str(jpg_folder)+"/"+(read[1][0])+".$F4.jpg" os.mkdir(version_folder) os.mkdir(jpg_folder) os.mkdir(hip_folder) hip_name_save = hip_folder+"/"+hip_name+".hip" hou.hipFile.save(hip_name_save) ##### Copy the viewer's current flipbook settings cur_desktop = hou.ui.curDesktop() scene = cur_desktop.paneTabOfType(hou.paneTabType.SceneViewer) flipbook_options = scene.flipbookSettings().stash() flipbook_options.frameRange((int(range_start),int(range_end))) flipbook_options.output(file_name) flipbook_options.gamma(float(gamma_in)) scene.flipbook(scene.curViewport(), flipbook_options) #newPath = file_name.replace('/', os.sep) #hou.ui.displayMessage(jpg_folder) #os.startfile(jpg_folder) Expand Have to admit that if im getting into VEX now, scripting and python has never been my area of expertise. It would be great to have a python script, which to from a selected folder, open each hip file, and save a flipbook thumbnail preview image of the last output selected. Or actually more interesting will be to have it operate every time you save the file, with the jpg preview image with the same name as the hip file... The script under the Houdini blue print web site is brillant Quote Link to comment Share on other sites More sharing options...
