18272 Fatal error Segmentation Fault! - Flip HELP ME!!!
I am trying to render a simulation done with a flip which is made up of 22 million particles. After having made several attempts the houdini console throws me a:
9576: Fatal error: Segmentation fault
Saving application data to ....
Here below I leave the image and the project files in case someone is willing to help me.
Thank you so much!!
Help me please!!!
Collider.obj
Test.hipnc
I would consider resizing the entire set up to scale down to a more reasonable size. Reduce the scale on every item by 100 times. Don't forget to bring the domain size down as well.
On 15/5/2020 at 4:11, Atom said:
Consideraría cambiar el tamaño de todo el conjunto para reducirlo a un tamaño más razonable. Reduzca la escala en cada artículo por 100 veces. No olvide reducir el tamaño del dominio también.
Hey bro!!... Thank You so much!!
