Vellum + RBD
starion83
Hi everyone,
I'd done a bit of searching around, and it seems like the answer is that vellum and RBD can't yet be combined into a single simulation. However I'm wondering if there's a way to fake RBD in vellum?
I'm trying to create an effect where glass cracks because a vellum object pushes against it. Is there some workaround to make a simple object 100% rigid using vellum?
Any help is greatly appreciated!
not 100%, but the lower the geo resolution the more rigid it can be (especially with Cloth/Trianglestretch constraints) given high enough stiffness and substeps/iterations, you'd ideally sim the glass as a single sided geo and extrude post sim
alternatively you can make soft/deformable objects in Bullet using soft constraints
Guys, thank you for the response!
Yes currently this has been the approach I landed on: split the sim into vellum / RBD. It seems to be doing the trick convincingly enough
Here's hoping that we get integration of vellum and RBD in the future
