Instance random keyframe/animation with Python
sant0s81
Good morning,
since I deeply fall in love with python, I would like to know where it makes sense to use Python or better VEX.
I have a cube, that has on each frame from 1-10 a random rotation keyframed.
Now I would like to copy/scatter these cube as a instance on a grid, but of course each cube should use a random animation of that 10 keyframes.
Does that make sense in Python?
And how would I start or what do I have to look for?
I also would like to specify that I only use a range of keyframes.
Lets say frames 1-5 have only rotation in x, frames 6-10 have rotation on y.
My first thougts are:
def pose_1_5_x():
     keyframes_x = hou.parmTuple('/obj/box_object1/box1/r')
     for frame in range(1, keyframes_x 1):
          frames = (get all keyframes)
          retime = frames (set all keyframes to frame 1)
          etc etc etc ^^
But I guess, thats total bullshit :D
I know, probably its more easy doing that in VEX or with for each - but would like to understand how to do that with Python.
Thanks alot! :)
I made some progress, still with problems :D
The plan now is to find a way in python, to randomize a range of frames and output that in a timeshift.
So far I have that:
import random
def retime_frames():
    # values from dropdown tokens
    fr_get = hou.evalParm('choose_frame_set')
    for frX in range(fr_get):
        fRandom = (random.choice(frX))
        hou.parm('retime_frame').set(str(fRandom))
        print fRandom
It gives me an error, that something with my strings is not okay.
A working version with a list inside is that:
    random_num = ['1', '2', '3', '4', '5']
    fRandom = (random.choice(random_num))
    frame = hou.parm('retime_frame').set(str(fRandom))
    return fRandom
As soon as I try to use a variable inside the list or create a range function, it does not work anymore.
range_randomize_retime_isntances_with_animations_v001.hiplc
range_randomize_and_retime_instance_with_animation_v1a.hdalc
Edited by sant0s81
  On 5/31/2020 at 2:28 PM, Atom said:
I don't think I would use Python at all, it is still single threaded. It's not going to scale very well when you throw a large object count at it.
Hey @Atom :)
Yeah, I also found some solutions for random instance with offset animation and it works.
Its more for learning purpose to understand python.
Lots of the stuff I am just doing in Python is probably total nonsense and quicker in VEX or just with nodes.
And good to know about the single threaded siatuation, makes sense!
Thanks for the example scene, works perfect and quick. :)
I made some progress.
Not much change, but some.
Only one more thing I wonder how to do that in the for loop.
Right now when I specify the frame range, I have to use a token like '1-10'.
But what, if I would like to have an extra numer or two different frame ranges? For example '1-10, 14, 20-25'
Thx alot :)
Here is the actuall scene and HDA.
Solution:
 else: a = int(frames)      to        else: fr_sequence.append(int(frames))
range_randomize_and_retimeFetching info... range_randomize_retime_isntances_with_animations_v001.hiplcFetching info...
instance_with_animation_v1a.hdalcFetching info...
Edited by sant0s81
