Gayane Posted June 1, 2020 Share Posted June 1, 2020 (edited) I came across a problem with heightfield scatter. The houses, that I want to copy to points are weirdly broken. Maybe it's the wrong way to create copies on the heightfield. Can you recommend a solution to this problem? cause I'm running out of ideas...Thank you! Heightfield_scatter_problem.hipnc Edited June 1, 2020 by Gayane Quote Link to comment Share on other sites More sharing options...
magbo Posted August 5, 2020 Share Posted August 5, 2020 Use a Pack node right before instancing. Don't really know why that is happening, but as a rule of thumb when instancing, using packed geometry saves a looot of memory. Also, if you want to transfer attributes (like materials, etc.) declare them in the Transfer Attributes section. Quote Link to comment Share on other sites More sharing options...
Noobini Posted August 6, 2020 Share Posted August 6, 2020 or... in your hf scatter, Define Pieces as Single Piece or From Attrib Single Piece sounds logical but from attrib got me scratching head...why it works.....what attrib ? there's no class..you can put ass in there still works... Quote Link to comment Share on other sites More sharing options...
