This is a question about displacement.
Hi. Like my reference image, I used displacement for the green color. (From Shader)
(viewport)
(render image)
1. How to soften the edges. (The edge naturally?)
2. I want to add noise to the green color once more, like using a lava shader.
3. It's confusing whether I need to do what I want to do in the shader or in the sop.
If you do it in the shader... Is there a way to visually check it in sop?
I also attach my hip file. Please advise.
Thanks in advance.
noise_test_dis.hipnc
