qLib Volume Remap
plazadelmar
Does someone have experience with this? I can't make it work. I have cached 100 frames of animation and my timeline is set to 200. After adding it after cache nothing shows up in my viewport. Nothing is processed either. Do I need to configure it in a different way? I have density and vel going in.
Edited by plazadelmar
1 hour ago, tamagochy said:
You should add animated frame range to Frame, no need use clamp. Then click on arrow at Vel Field Scale and choose compute from Frame
I did that but the problem is that nothing is showing up in my viewport. As soon I'm activating the node the smoke is gone. Could you send me a basic example?
Got this message from the qLib team... "The "Frame" parameter should be animated with a retime curve. However, this node is retained for 16.5, from 17.0 it's better to use the built-in Retime SOP. It essentially does the same thing but will be 2-3 times faster (as it's C++ and not VEX)."
