unique ids in a continuous vellum simulation
suesssebastian
Hi.
I'm new to vex and have a problem i can't get my head around.
I created a little simulation where paper gets blown away every 6th frame.
Now i want to give every page an unique id, but counting upwards.
so my code is:
f@idpage;
if(@Frame%6 == 1){
   @idpage+=1;
I@ know its not counting because every frame, the attrib is set back to 0.
But how can i count my IDs in dops or on a global level?
Paper_Wind_02.hiplc
SOPs re-evaluates the node tree every frame so there is no history, just whatever the nodes evaluate to at that frame.  Check out the Solver SOP for accumulating values ( https://www.tokeru.com/cgwiki/index.php?title=The_solver_sop  is a great resource).
In this particular case, if you just need a unique name you can use the "patchname" attribute already output by vellum with a slight tweak to the name you had set in geo1_vellum
