VEX: find the max of the max of bounding boxes of connected pieces
anicg
For each connected piece, get the bounding box, find the axis with the maximum scale and remember just the number. Say e.g. a box is 18 by 3 by 2, a grid is 4 by 7, a sphere is 15 by 15 by 15 then we need 18, 15, and 7.
Then find the max of these maxs (18 vs 7 vs 15) and assign it to an attribute, such that we end up f@maxattrib = 18.
Edited by anicg
Put to point wrangle
int pts[] = neighbours(0,@ptnum);
float dists[];
foreach(int pt; pts){
    vector pos = point(0,"P",pt);
    vector dir = pos-@P;
    float dist = length(dir);
    append(dists,dist);
dists = sort(dists);
float d = dists[-1]; //longest
f@d=d;
setdetailattrib(0,'dist',d,'max');
in first input connect all bounding boxes
  • 2 weeks later...
float dists[];
    append(dists,dist);
f@d=d;
Thank you, I'm almost there, I get an attribute d which has 7,9 and 21, I only need the 21, the highest number, one value, what do I need to add to get that?
you can also just directly merge your geo (without appending Bound SOP to each)
use Connectivity in Point mode to compute connectivity attribute, default i@class for example
then Point Wrangle:
vector scale = getpointbbox_size(0, "@class=" + itoa(i@class));
float max = max(scale);
setdetailattrib(0, "max", max, "max");
should give you what you need
then Point Wrangle:
Is the getpointbbox working in world coordinates? But if you need oriented bounds this code not enough I thinks.
Right, it doesn't do oriented bounding box
You would need to transform your pieces by inverted oriented transform before that node to get the oriented bbox lengths
Unless they are packed and then oriented in which case you can use bounds intrinsic
