Can @group_NAMEOFGROUP be a variable?
ianwww
In a point wrangle I create a new group, say mynewgroup, and set membership of it based on some criterion.  Later in the wrangle I want to test for membership of that new group.  I can't use inpointgroup because that looks backward to the previous node, where the newly created group doesn't exist.  So, instead I use
if(@group_mynewgroup)
	WHATEVER
to test for a point's membership of the new group mynewgroup.  To use @group_ syntax I need to hard code the mynewgroup into it.
What if the name of the new group depends on the outcome of some code inside the wrangle so that I need to create the new group name on the fly?
I'd like to be able to use something like
string newgroup = concat('group_', 'mynewgroup');
if(@newgroup)
	WHATEVER
I know this particular code doesn't do it but is there something along these lines that I could use?
  • 3 weeks later...
As well as setting up a group first time around, also declare a variable for you purpose to:
int result=0;
If(condition){
   @group_grp=1;
   result=1;
Later, in the wrangle:
if(result){
   do something;
Thanks for the suggestion but - and I may be misunderstanding something - in your example wouldn't
if(@group_grp)
and
if(result)
be asking the same thing?  Both were manually set to 1 at the same time when condition was met, so result is just a mirror variable isn't it?
Also, I'd still need to hard code the name of @group_grp in advance of knowing what the name should be.
Sorry if I've misunderstood!
