Noise type value visualization
Trilec
Hopefully this is helpful to others.
Small snippet to visualize the different noise's. I have not put them all in, but if you feel inclined please add more and reply-post.
You will need to create the menu (as this does not seem possible in VEX and has to be done via the parameter interface?
and a 100x100 grid as input.
// Houdini Noise visulization - Curtis
int  NoiseMenu = ch("NoiseMenu");
// Create a Ordered Menu "NoiseMenu", In the "Pram Interface",
//Token, Lable ...
// 0 vnoise
// 1 wnoise
// 3 flownoise
// 4 curlnoise
// 5 xnoise
// 6 random
// 7 alligator
float   frequency = ch("frequency");
float   rough = ch("roughness");
float   atten = ch("attenuation");
float   jitter = ch("jitter");
int     turbulence = ch("turbulence");
int     flow = ch("flow");
int     seed = ch("seed");
//Noise data
vector  vp0, vp1;
float   output1=0;
float   output2=0;
//No Case stament in VEX ... elseif it is..
if ( NoiseMenu == 0 ){
    //vnoise VEX function
    //Generates Voronoi (cellular) noise.
    vnoise(@P, set(jitter, jitter, jitter), seed, output1, output2, vp0, vp1);
else if ( NoiseMenu == 1){
    //wnoise VEX function
    //Generates Worley (cellular) noise.
    wnoise(@P, @P.z*frequency, output1, output2); //general noise
else if ( NoiseMenu == 2){
    //snoise VEX function
    //functions are similar to wnoise.
    output1 = snoise(@P,  turbulence, rough, atten);
else if ( NoiseMenu == 3){
    //flownoise VEX function (soft)
    //Generates 1D and 3D Perlin Flow Noise from 3D and 4D data.
    output1 = flownoise(@P*frequency,  flow);
else if ( NoiseMenu == 4){
    //curlnoise VEX function
    //Computes divergence free noise based on Perlin noise.
    output1 = curlnoise(@P*frequency);
else if ( NoiseMenu == 5){
    //xnoise VEX function
    //Simplex noise is very close to Perlin noise
    output1 = xnoise(@P*frequency);
else if ( NoiseMenu == 6){
    //random VEX function
    //Generate a random number based on the position in 1-4D space.
    output1 = random(@P*frequency);
else if ( NoiseMenu == 7){
    //anoise VEX function
    //Generates "alligator" noise.
    output1 = anoise(@P*frequency,turbulence, rough, atten);
//Output to 100x100 grid as colour
@Cd = output1;
  • Like 2
  • 4 months later...
//Token, Lable ...
// 0 vnoise
// 1 wnoise
// 3 flownoise
// 4 curlnoise
// 5 xnoise
// 6 random
// 7 alligator
//Noise data
vector  vp0, vp1;
float   output1=0;
float   output2=0;
@Cd = output1;
Curtis @Trilec, my old fiend, how are you mate? Where are you working on in Germany?
Thanks you for this one. I see you as me are houdini's addicted now
Here's one i could share below
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998) (my procedural work for the Netfix'serie is about to end, lkooking for a new adventure to jump on now)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
// wrapper function for different noises, angle ramp
float noise_wrapper(vector Q; int id)
    float r;
    if (id == 0)
        r = float(anoise(Q));
    } else
    if (id == 1)
        r = float(onoise(Q));
    } else
    if (id == 2)
        r = float(snoise(Q));
    } else
    if (id == 3)
        r = float(curlnoise(Q));
    } else
        r = float(noise(Q));
    return r;
// get the number of multiparm
int n = chi('para');
// init string
string s;
vector up = set(0,1,0);
float angleN = acos(dot(v@N, up));
for (int i = 0; i < n; i++)
    // multiparm index (as string)
    s = itoa(i+1);
    float angle = radians(chf('angle' + s));
    float rangea = radians(chf('rangea' + s));
    float eps = 1e-3;
    if (rangea < eps)
        return;
    // fit angle to interval
    float a = efit(angleN, angle - rangea, angle+rangea, 0, 1);
    if ((a > 1) || (a < 0))
        a = 0;
    // evaluate ramp multiplier
    float r = chramp('ra' + s, a);
    // rescale noise
    r *= chf('amount' + s);
    // use noise multiplier/offset
    vector nm = chv('nm' + s);
    vector no = chv('no' + s);
    int id = chi('nt' + s);
    @P += v@N * noise_wrapper(nm*@P + no, id) * r;
