I am using Houdini 17.5.173 and this is my .env
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup.  They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
#    VAR = VALUE
# Values may be quoted
#    VAR = "VALUE"
# Values may be empty
#    VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOUDINI_DSO_ERROR = 2
PATH = "C:/ProgramData/Redshift/bin;$PATH"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/17.5.173;&"
I keep getting this error:
The directories are 100% right. I am out of ideas.
  • 3 months later...
Due to the numerous updates of Houdini, depending on the version of redshift, support is dropped for older builds of houdini versions.
It is strongly recommended to use the latest version of production build.
17.5.460 for 17.5
You can find the list of compatibility in the read me of the redshift install folder, or on the redshift site
17.5.460 for 17.5
thanks a lot!!! it´s working with the 17.5.460 build.
