Redhsift broke and I cant fix it
Hello GUYS!
I am using Houdini 17.5.173 and this is my .env
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup.  They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
#    VAR = VALUE
# Values may be quoted
#    VAR = "VALUE"
# Values may be empty
#    VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOUDINI_DSO_ERROR = 2
PATH = "C:/ProgramData/Redshift/bin;$PATH"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/17.5.173;&"
I keep getting this error:
The directories are 100% right. I am out of ideas.
Your Redshift version does not support this houdini build most likely.  Make sure you read the release notes of the redshift version for supported houdini builds, this is most likely a question for the Redshift forum, Juango would be happy to help.
