@orient attribute to @N an @up?
ron2812
Hi everyone!
Is there a way to calculate @N and @up from the @orient attribute?
Basically the same as the orient to curve SOP does - it only outputs N and up, but i got all the Pitch/Yaw/Roll bells and whistles.
I have everything layed out on my curve the way i want, but Unreal Engine doesn't seem to read the orient attribute.
Thanks in advance!
Hi Ronald, here is the extraction of axes from quaternion in vex:
matrix3 m = qconvert(p@orient);
v@xaxis = set(m.xx, m.xy, m.xz);
v@yaxis = set(m.yx, m.yy, m.yz);
v@zaxis = set(m.zx, m.zy, m.zz);
The default orientation of v@N is zaxis, and @up is yaxis. So this is probably what you need:
v@up = set(m.yx, m.yy, m.yz);
v@N  = set(m.zx, m.zy, m.zz);
