curv.u Posted August 28, 2020 Share Posted August 28, 2020 Hello, i come to you after several sleepless nights due to a matter i can't find a solution. Hopefully some of you may provide help. In my project i have one geo, replicated and simulated in vellum with "Instance on points" method: every 4 frames a new geo is created and the simulation starts. Now i have trouble point deforming the proxy simulated geo with the original geo, because Hi-res and Rest geos should appear exactly when a new proxy is created. I thought it would suffice a ForEach and something like a Birthid attribute to isolate every guy, but it seems i'm not able to make it work. Below the hipfile attached: i simplified it and replaced my original geo with a Rubbertoy; so don't mind too much attention to the shape of the proxy geo... now it's strange, but in my case it did the work. I really hope in some clarifications with the script, i'm stuck there. Thank you very much! pointdeform.hipnc Quote Link to comment Share on other sites More sharing options...
kube Posted March 31 Share Posted March 31 did you find a solution for that? I´m having the exact same problem, trying to pointdeform on newly emitted lowpoly geo. I tried giving a birth id for each emitted geo and then pointdefom it in a for each loop, but I seem to be doing something wrong. Quote Link to comment Share on other sites More sharing options...
fencer Posted March 31 Share Posted March 31 I guess something close was discussed earlier 1 Quote Link to comment Share on other sites More sharing options...
kube Posted April 1 Share Posted April 1 1 hour ago, fencer said: I guess something close was discussed earlier thanks man! Quote Link to comment Share on other sites More sharing options...
