Gradient group transfer
Hi all,
I'm looking into a way to apply a "feather" effect to a group transfer. I this case I would like to have a grid of points where the edges are selected with a gradient to apply a higher level of detail. (See image)
My thoughts sofar was to create a box around my grid and use group transfer with a distance threshold. However, this cuts off rather abruptly causing less of a gradient and more of a border.
I've made a .hip file (attached) where I've attempted a rudimentary "bleeding effect" What I did for those who don't want to check the .hip is selected the border, then over a series of nodes selected a higher random number of points with a smaller distance threshold. This works though it is very messy/inefficient and isn't very user friendly.
My question is how to approach this in a more procedural manner?
And a follow-up question would be how to apply such a gradient grouping based on other objects, for example, a camera. Though this is less needed and more of a pondering.
Any help would be appreciated.
-Thomas
Gradientgroupselect.hip
That sounds great! However, I believe this is a feature in 18.0. Which of course won't work in 17.5.
Is there a way of getting this to work in 17.5 without having to upgrade?
Edit: it doesn't have to be as elegant as the distance from geometry-node but something we can use before we've made the switch to 18
Edited by netherknight
