How to refer the png image data to the render view
yujiyuji
it's because File SOP imports image as Volume with viewport visualisation, which if you want to match you need to use Cd field in the shader
however you probably want just texture mapped cards, which you can either
- create grid and map your texture to it
- or create Reference Image Object
- or in sops create COP2 Network with File COP inside and let it output the image as Mesh
  • Thanks 1
I could make it!!
Thank you very much!!!! Really!!
