DonRomano Posted September 22, 2020 Share Posted September 22, 2020 Hey guys, I'm facing a little problem : Houdini does not load my OCIO config (I'm using aces 1.0.3). I've set up the OCIO variable, it works well with Nuke, Maya, but Houdini is not loading it and I can't even load it manually when I open the color settings : If someone knows what can cause this, I'll be glead to read it ! Cheers, Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted September 22, 2020 Share Posted September 22, 2020 Hi, I copied OpenColorIO-config folder to my home directory and set up desktop environment variable OCIO to the path of config.ocio and that's it. Houdini is picking it up automatically. aces 1.0.1 Quote Link to comment Share on other sites More sharing options...
DonRomano Posted September 22, 2020 Author Share Posted September 22, 2020 21 minutes ago, vicvvsh said: Hi, I copied OpenColorIO-config folder to my home directory and set up desktop environment variable OCIO to the path of config.ocio and that's it. Houdini is picking it up automatically. aces 1.0.1 Yes, that's what I did but Houdini is not picking it up. Nuke, Maya and other softs works well with it, even Redshift within Houdini, but Houdini itself won't load it. Quote Link to comment Share on other sites More sharing options...
shinkata Posted July 13, 2021 Share Posted July 13, 2021 I put this in my houdini.env OCIO = C:\aces_1.0.3\config.ocio and works! Quote Link to comment Share on other sites More sharing options...
