Python parameter expression not re-cook node
Alizarin
Hello!
I am trying to implement python expressin in Object Merge node  in parm "objectpath1"  to get geometry from connected nodes to parent geo. So as final result if you connect/disconnect  first input of test node geometry should switch to another one. Actually script working fine and storke  of parm updating if i connect or disconect ANIM node, but object merge node do not updating geometry while i turn on/off  "Enable Merge" toggle on object merge node.  It's seems node just not cooking properly.
 Any suggestions how to solve this problem? Or maybe hscrip variant?
P.S. check test setup in hip uploaded
switch.hipnc
