Prim Attr to group for material assignment
Hey,
Trying to workout a good asset workflow coming from Maya to Houdini.
Geometry wise we are using Alembic and I'd like to add an attribute in Maya (or similar method) to define what materials are assigned to what geometry (shape assignment, never face assignment). Then in houdini use that attribute to assign materials to the alembic cache.
So far I've managed to add a string attr to the shape nodes in Maya and export that into houdini fine. Once the alembic is unpacked I can see the attributes there.
I cant seem to get those prim attributes to be used in the material node downstream though, as you could do with groups for instance.
Any tips would be much appreciated, or other workflows that could be better.
Cheers
Hey mate, the syntax for using an attribute as a group is slightly different. If you wanted to use the string name attribute for example:
Or alternatively, if you wanted to use anything beginning with "prim_"
Hope this helps.
Edited by aaronsmith93
  • Haha 1
Hope this helps.
Thanks for the quick reply mate, thats exactly what I was after!
