"GameDev Path Deform" issue with overlapping areas...
Masoud
Hi guys;
I tried to deform a box using "GameDev Path Deform" as you can see in the image below which works fine but how can I fix the artifacts (penetrations) at the overlapping areas?
(I mean I need to fix the penetrations and make a clean topology).
Thanks for helping.
PathDeform.hip
Edited by Masoud
100 % Its possible .I'm just not qualified for that Task ;)..I can visualize and draw in mine Head  ..but lack of the knowledge  ..
someone maybe gonna Help :wub:
Maybe if we use this code for intersection inside Path deform and make something different
//verti
vector getIntersection(vector A;vector B;vector C;vector D;int test)
   if(A==B || C==D) return B;
   vector n1 = normalize(B-A);
   vector n2 = normalize(D-C);
   if(abs(1.0-abs(dot(n1,n2)))<1e-5){
       test = 0;
       return B;
   vector AC = C - A;
   float d1 = ( dot(n1,AC) - dot(n2,AC)*dot(n1,n2) ) / ( 1 - dot(n1,n2)*dot(n1,n2) );
   float d2 = ( -dot(n2,AC) + dot(n1,AC)*dot(n1,n2) ) / ( 1 - dot(n1,n2)*dot(n1,n2) );
   if(d1<0 || d2<0){test=0;return B;}
   else if(d2>distance(C,D)){test=0;return B;}
   vector p1,p2;
   p1 = A + d1*n1;
   p2 = C + d2*n2;
   test = 1;
   return p2;
int listPoints1[] = primpoints(1, 0);
vector A = point(1,"P",listPoints1[0]);
vector B = point(1,"P",listPoints1[1]);
int curPrimOnC= vertexprim(0,@vtxnum);
int curPrimOnD= vertexprim(0,@vtxnum+1);
if(curPrimOnC!=curPrimOnD){
    removepoint(0,vertexpoint(0,@vtxnum));
    return;
vector C = point(0,"P",vertexpoint(0,@vtxnum));
vector D = point(0,"P",vertexpoint(0,@vtxnum+1));
vector p=C;
int test = 0;
p = getIntersection(A,B,C,D,test);
if(test==1){
    addpoint(1,p);
//prim
vector getIntersection(vector A;vector B;vector C;vector D)
   if(abs(1.0-abs(dot(n1,n2)))<1e-5) return B;
   vector AC = C - A;
   if(d1<0 || d2<0) return B;
   else if(d2>distance(C,D)) return B;
   vector p1,p2;
   p1 = A + d1*n1;
   p2 = C + d2*n2;
   return p2;
int listPoints1[] = primpoints(0, @primnum);
vector A = point(0,"P",listPoints1[0]);
vector B = point(0,"P",listPoints1[1]);
vector p=B;
float minimumDist = 1e+6;
for(int i=0;i<nprimitives(1);i++){
    int listLinearVertices[] = primvertices(1, i);
    for(int curIndex=0;curIndex<len(listLinearVertices);curIndex++){
        int curPrimOnC = vertexprim(1,listLinearVertices[curIndex]);
        int nextIndex = curIndex+1;
        int curPrimOnD = vertexprim(1,listLinearVertices[nextIndex]);
            continue;
        vector C = point(1,"P",vertexpoint(1,listLinearVertices[curIndex]));
        vector D = point(1,"P",vertexpoint(1,listLinearVertices[nextIndex]));
        vector outP = getIntersection(A,B,C,D);
        if(outP!=B && distance(B,outP)<minimumDist){
            p = outP;
            minimumDist = distance(B,outP);
removeprim(0, @primnum, 1);
addpoint(0,p);
It works if  You make poly expand before Path deform :wub:
Edited by Librarian
