L-system Dragons and Robots FUN
Librarian
  • 2 months later...
  • 1 year later...
Thank you for this file @Sleng! This file used to work in Houdini 18 but with Houdini 19 there is a visual glitch that seem to occur starting with the node "foreach_end2".
Does anyone know why this occurs? Haven't seen it on any other projects I have. If I try to move the camera the model disappears.
Edited by Thoi
4 hours ago, oneXone said:
You can fix it with 2 steps
1 - in "fuse1" at the top of the left loop increase the snap distance to 0.0015.
2 - remove (or replace) the null named "We_are_Done_Here_2"
That did it! Thank you so much @oneXone
