Alan Monroig Posted October 19, 2020 Share Posted October 19, 2020 Hello, I have two different DOP Objects (RBD Packed) and I want to source Geometry into just one of the objects, not both. I am using the popsource node which by default sources to both of my objects. (Using just one object is not an option for now) Any tips? Thanks! Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted October 19, 2020 Share Posted October 19, 2020 Hi, you can delete one object in a sopsolver dop, though i am not sure i understood you completely. You should upload simple example of what you're trying to do. Quote Link to comment Share on other sites More sharing options...
Masoud Posted October 20, 2020 Share Posted October 20, 2020 Hi; Please explain more, or upload a hip or image file. Quote Link to comment Share on other sites More sharing options...
Alan Monroig Posted October 23, 2020 Author Share Posted October 23, 2020 I found a solution using a switch solver which does exactly what I needed. 1 Quote Link to comment Share on other sites More sharing options...
