Problem with Vellum and Rest Length
Alan Monroig
I need help solving this issue! it is driving me crazy…
When I increase the Rest Length attribute of a pressure constraint (using vellumconstraintproperty and restlengthscale parameter). The object moves erratically, unstable…
I have tried with different resolution geometry, sim scale, substeps, constraint iterations, smoothly animating the attribute, etc..
Do not know how else to troubleshoot.
Thank you in advanced,
Alan
vellum_problem.hiplc
On 10/19/2020 at 10:42 AM, Noobini said:
look here:
https://www.sidefx.com/tutorials/advanced-vellum-workflows-h17-masterclass/
last chapter is where inflation is shown. Go get the pbd_inflatable_toy file and study it.
here's a quick adaptation.
vellum_problem_fix.hipnc
Hello,
Thank you, but... your file does not solve the issue, if I increase the Rest Length higher than 1 (which is what you enabled) it turns unstable. The restscale attribute you tried to change through VEX does no effect because you ticked the wrong parameter. I will take a look at the masterclass.
