tsaid Posted November 6, 2020 Share Posted November 6, 2020 (edited) I am playing with the Spreading Fire shelf tool and I can't figure out how to animate fire to start burning from nothing. I tried to animate Temperature (Attribute Wrangle) but ends up returning no burn and no fire at all. Then I set Start Frame at the latter frame, which does delay, but the fire would pop up burning. Lastly, I tried animating the Initial Fuel, and Ignition Temperature (Pyro Source Spread) and still with no luck so far. Anything I might overlook? Edited November 6, 2020 by tsaid Quote Link to comment Share on other sites More sharing options...
Atom Posted November 7, 2020 Share Posted November 7, 2020 (edited) Try animating the Fire Intensity Scale on the Look tab of the pyrosolver. Animate the value from 0 to 15. Edited November 7, 2020 by Atom Quote Link to comment Share on other sites More sharing options...
tsaid Posted November 7, 2020 Author Share Posted November 7, 2020 1 hour ago, Atom said: Try animating the Fire Intensity Scale on the Look tab of the pyrosolver. Animate the value from 0 to 15. Thanks for the hint, Atom!!! However, I can't find the Fire Intensity Scale nor the Look tab in pyrosolver..... I should have mentioned that it's a pyrosolver (sparse) that's being used in the network but I checked both and couldn't find it yet. Or would that be a case that it's in 18.5? I will update and take a look. Quote Link to comment Share on other sites More sharing options...
