scuy Posted November 29, 2020 Share Posted November 29, 2020 1 st step , render geometry with polar projection. 2 step , map to 1st step texture to sphere. then ,near y axis texture is broken . If i changed sphere resolution to higher , still bad result. Dose anyone know solution ?? or this detail is limit of Houdini algorithm (projection and mapping ) ??? I've attached test fip file. Thank you. 1_tes.hiplc Quote Link to comment Share on other sites More sharing options...
nuki Posted November 30, 2020 Share Posted November 30, 2020 (edited) uv is a vertex attribute so yeah - the geometry resolution has an impact. Press space+5 in the viewport to switch to uv view - your coords are outside the 0-1 range which might cause issues when baking. I suspect thats the issue as with larger faces the jaggedness of the boundary is more pronounced. Edited November 30, 2020 by nuki Quote Link to comment Share on other sites More sharing options...
nuki Posted December 1, 2020 Share Posted December 1, 2020 thinking about it again, switching to a 'polygon mesh' sphere should fix the seam. maybe also drop down a uvlayout sop to fit the uvs 0-1. cant test baking as i dont have redshift unfortunately. Quote Link to comment Share on other sites More sharing options...
scuy Posted December 2, 2020 Author Share Posted December 2, 2020 Dear nuki Thank you advice. You are right , uv is over 0-1. so , fixed ad type : polygonmesh , and adjust uv 0-1 , it went well. Thank you good solution!! 1 Quote Link to comment Share on other sites More sharing options...
