NYXD Posted December 6, 2020 Share Posted December 6, 2020 Hi! I'm actually trying to get trough the tutorial series of Houdini "Destruction FX", and I need to use the Minimal OpenCl Solve for a Pyro Sim. But as soon as I turn it on, my console pops up with tons of errors showing up! I couldn't find something talking abt it on the internet as it is a pretty new feature, so if anyone knows how I could solve that it would be perfect. Here is the massive error message: In file included from C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include\CVDBUtil.h:31: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:22:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[0] = floor(xyz->mVec[0]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:23:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[1] = floor(xyz->mVec[1]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:24:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[2] = floor(xyz->mVec[2]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:117:23: note: expanded from macro 'CREATE_LERPSIMPLE' cnanovdb_lerp##SUFFIX(VALUETYPE a, VALUETYPE b, float w) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:117:36: note: expanded from macro 'CREATE_LERPSIMPLE' cnanovdb_lerp##SUFFIX(VALUETYPE a, VALUETYPE b, float w) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:115:46: note: expanded from macro 'CREATE_LERPSIMPLE' #define CREATE_LERPSIMPLE(VALUETYPE, SUFFIX) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:234:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec -= 0.5; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:236:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec += 1.0; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:238:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec -= 0.5; ^ error: front end compiler failed build.clBuildProgram (-11) OpenCL Exception: In file included from :1: In file included from C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include\CVDBUtil.h:30: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:84:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mMatD[9]; // r,c = 3*r + c ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:85:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mInvMatD[9]; // r,c = 3*r + c ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:86:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mVecD[3]; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:87:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mTaperD; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:221:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mBBox[6]; // 48B. floating-point bounds of active values in WORLD SPACE ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:222:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mVoxelSize[3]; // 24B. size of a voxel in world units ^ In file included from :1: In file included from C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include\CVDBUtil.h:31: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:22:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[0] = floor(xyz->mVec[0]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:23:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[1] = floor(xyz->mVec[1]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:24:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[2] = floor(xyz->mVec[2]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:117:23: note: expanded from macro 'CREATE_LERPSIMPLE' cnanovdb_lerp##SUFFIX(VALUETYPE a, VALUETYPE b, float w) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:117:36: note: expanded from macro 'CREATE_LERPSIMPLE' cnanovdb_lerp##SUFFIX(VALUETYPE a, VALUETYPE b, float w) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:115:46: note: expanded from macro 'CREATE_LERPSIMPLE' #define CREATE_LERPSIMPLE(VALUETYPE, SUFFIX) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:234:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec -= 0.5; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:236:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec += 1.0; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:238:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec -= 0.5; ^ error: front end compiler failed build.clBuildProgram (-11) OpenCL Exception: In file included from :1: In file included from C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include\CVDBUtil.h:30: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:84:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mMatD[9]; // r,c = 3*r + c ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:85:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mInvMatD[9]; // r,c = 3*r + c ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:86:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mVecD[3]; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:87:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mTaperD; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:221:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mBBox[6]; // 48B. floating-point bounds of active values in WORLD SPACE ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CNanoVDB.h:222:5: error: use of type 'double' requires cl_khr_fp64 extension to be enabled double mVoxelSize[3]; // 24B. size of a voxel in world units ^ In file included from :1: In file included from C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include\CVDBUtil.h:31: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:22:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[0] = floor(xyz->mVec[0]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:23:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[1] = floor(xyz->mVec[1]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:24:41: warning: double precision constant requires cl_khr_fp64, casting to single precision coord->mVec[2] = floor(xyz->mVec[2]+0.5); ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:117:23: note: expanded from macro 'CREATE_LERPSIMPLE' cnanovdb_lerp##SUFFIX(VALUETYPE a, VALUETYPE b, float w) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:117:36: note: expanded from macro 'CREATE_LERPSIMPLE' cnanovdb_lerp##SUFFIX(VALUETYPE a, VALUETYPE b, float w) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:124:19: error: use of type 'double' requires cl_khr_fp64 extension to be enabled CREATE_LERPSIMPLE(double, D) ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:115:46: note: expanded from macro 'CREATE_LERPSIMPLE' #define CREATE_LERPSIMPLE(VALUETYPE, SUFFIX) \ ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:234:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec -= 0.5; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:236:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec += 1.0; ^ C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/ocl/include/CSampleFromVoxels.h:238:25: warning: double precision constant requires cl_khr_fp64, casting to single precision qxyz.mVec -= 0.5; ^ :103:19: warning: double precision constant requires cl_khr_fp64, casting to single precision if (s_speed < V_EPSILON && t_speed < V_EPSILON) ^ :90:19: note: expanded from macro 'V_EPSILON' #define V_EPSILON 1e-10 ^ :103:42: warning: double precision constant requires cl_khr_fp64, casting to single precision if (s_speed < V_EPSILON && t_speed < V_EPSILON) ^ :90:19: note: expanded from macro 'V_EPSILON' #define V_EPSILON 1e-10 ^ :106:24: warning: double precision constant requires cl_khr_fp64, casting to single precision else if (s_speed < V_EPSILON) ^ :90:19: note: expanded from macro 'V_EPSILON' #define V_EPSILON 1e-10 ^ :108:24: warning: double precision constant requires cl_khr_fp64, casting to single precision else if (t_speed < V_EPSILON) ^ :90:19: note: expanded from macro 'V_EPSILON' #define V_EPSILON 1e-10 ^ :118:22: warning: double precision constant requires cl_khr_fp64, casting to single precision if (dp > 1 - A_EPSILON) ^ :91:19: note: expanded from macro 'A_EPSILON' #define A_EPSILON 1e-5 ^ :124:22: warning: double precision constant requires cl_khr_fp64, casting to single precision if (dp < A_EPSILON - 1) ^ :91:19: note: expanded from macro 'A_EPSILON' #define A_EPSILON 1e-5 ^ error: front end compiler failed build.clBuildProgram (-11) Quote Link to comment Share on other sites More sharing options...
nuki Posted December 6, 2020 Share Posted December 6, 2020 (edited) wanna share your computer specs? could be drivers, hardware... what precision are you using for your grids? Edited December 6, 2020 by nuki Quote Link to comment Share on other sites More sharing options...
NYXD Posted December 6, 2020 Author Share Posted December 6, 2020 I'm working on a pretty old laptop with a geforce 720M, an Intel Core i3 3110M and 8 go of RAM. I checked my graphic driver with Nvidia Geforce experience and it seems like I've already the best one for my laptop... And sorry but I don't know what u mean about my grids? Wich grids? (I'm a beginner) I drop u the .hipnc file below so you can check everything u want! House_Destruction.hipnc Quote Link to comment Share on other sites More sharing options...
nuki Posted December 7, 2020 Share Posted December 7, 2020 (edited) The errors indicate your card is missing an extension for double precision float types (64 bit float). But the 720m supports OpenCL 1.1, which should know this type. I guess updating drivers couldnt hurt, but dont expect too much. I have a 780gtx in my rig and while eg. the minimal solver shelf tool explosion technically works, its hardly usable for anything than a really, really coarse preview (exceeding vram i guess). When it works its fast tho. Since my gpu is from the same series I tested your scene and it works fine. Maybe its better to ask the sidefx forum, since thats a bit closer to the devs. Edited December 7, 2020 by nuki 1 Quote Link to comment Share on other sites More sharing options...
