hou.hipFile.merge opening file?
Mozzarino
Hello fellow magicians,
I'm using PySide2 and PyQt to make a button that merges an already existing .hip file with the current open scene.
After reading the Documentation, I'm under the impression that the method hou.hipFile.merge('path_to_merging_file') is what I'm looking for... But after using this method, Houdini tries to load the file in the path.
Can some one point out what I'm doing wrong?
Solved: I think the problem was that I didn't have my current open scene saved... And Houdini also imports the display options from the merged file, so I thought I was in the .hip file I wanted to merge :lol:
Edited by diogomgf
from PySide2 import QtWidgets, QtCore
def p_something():
    print "Hello"
dialog = QtWidgets.QWidget()
dialog.setParent(hou.qt.mainWindow(), QtCore.Qt.Window)
button = QtWidgets.QPushButton("Click")
button.clicked.connect(p_something)
v_layout = QtWidgets.QVBoxLayout()
v_layout.addWidget(button)
dialog.setLayout(v_layout)
dialog.show()
I learned Heeloooo
Here You have Fun ...Python and Other Scripts just do searching
https://fereria.github.io/reincarnation_tech/10_Houdini/11_SOLARIS/90_solaris_lop_node/#python
