soft selection
saca
hi,
i want to apply any effects into geometry by it"soft selection".
in 3dsMax,  is very popular technique , it's very simply operation.
i had heared, in houdini it's attribute blur.
attribute blur work well on Polygon geometry,
but "polygon-curve" is not soft result.
What should i do?
if you can, please check  my file.
this sample apply ray_sop by "softWeight" attribute.
thanks
SoftSelection_v001.001.hipnc
  • 2 months later...
I'm sorry so late.
i had found very nice tutorial about soft-selection.
"HOUDINI FOR THE ARTIST: WORKING WITH THE FALLOFF NODE"
https://lesterbanks.com/2018/11/houdini-new-falloff-node/
H.17 falloff(SOP),
but in H.18, it's distanceAlongGeometry(SOP).
distanceAlongGeometry(SOP) output "dist" atrribute.
showing H.18 version.
FallOff_SoftSelection_v001.001OD.hipnc
