psychopoet Posted December 29, 2020 Share Posted December 29, 2020 i'm making a ocean plane. displacement is working when I open houdini and render. but submit that hqueue it doesn't work. checked that image it was just a plane. Anyone knows why that happen?? please help Thank you Quote Link to comment Share on other sites More sharing options...
Matt_K Posted December 29, 2020 Share Posted December 29, 2020 Hey - without seeing your setup, the first thing I would check is that the displacement texture is reachable from all render nodes. When rendering via network, the usual suspect with render errors is the path to assets / textures not being available to the render nodes. Hope that helps.. Quote Link to comment Share on other sites More sharing options...
psychopoet Posted December 29, 2020 Author Share Posted December 29, 2020 Thank you Matt i think the path is reachable but it still doesn't work. i attach my setting Quote Link to comment Share on other sites More sharing options...
mathieuN Posted January 12, 2021 Share Posted January 12, 2021 Can you attach an outpulog, because is current error in Hqueue, it can't apply the remap variable fron local server letters to unc path for the render nodes. Hope it's help Mathieu Quote Link to comment Share on other sites More sharing options...
