haskellf Posted January 6, 2021 Share Posted January 6, 2021 My first post - YES! What would be the best way to use "copy to points" (or SOP / VEX alternative) that will copy random sized boxes (i.e. shelf of books of various thickness or a black of attached homes) onto the curve but move/offset the position so that the objects do not overlap. I assume I would need to use a foreach statement to do the check but. I watched a couple of tutorials on how to create a bookshelf but they assume that all the books are the same size and fit within the resample space. Quote Link to comment Share on other sites More sharing options...
Librarian Posted January 9, 2021 Share Posted January 9, 2021 Welcome @haskellf I like UV-Layout for that , you have Endless variation in vex to do this ..Here it some File and Links For some Knowledge ..Have Fun https://github.com/kiryha/Houdini/wiki/vex-for-artists https://www.tokeru.com/cgwiki/index.php?title=JoyOfVex VariantCopyUVlayOut.hiplc Quote Link to comment Share on other sites More sharing options...
haskellf Posted January 12, 2021 Author Share Posted January 12, 2021 thanks, much appreciated and ill also look at those links. Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted January 19, 2021 Share Posted January 19, 2021 (edited) It's trivial nowadays, thanks to Chain SOP (since 18.5) Have a look at the 18.5 presentation (H18.5 LAUNCH EVENT on Sidefx.com) Proof: books.hipnc Edited January 19, 2021 by AntoineSfx 2 Quote Link to comment Share on other sites More sharing options...
