Volume - Sample attr from point - Strange behaviour
BenWall
Hey there,
After spending a fair amount of time on SOP and VEX, I'm now learning basic volumes handling. I found a behavior I don't really understand and can't find any ressources on the subject.
I created a simple setup to change the density of a scalar volume with the distance to a point. Everything works as expected, but when I move the point to a bound of the volume, the density from on side seems to be "reflected" on the other side of this volume. Looking at the screenshot, we should only get yellow values on the left (where the point is), the right side should be blue.
Seems to me there are three possibilities here:
- My volume wrangle might be wrong,
- There is something I didn't understand about volumes,
- There is something wrong with the way I setuped the volume visualization.
Can someone explain what I didn't get right?
Thanks
strange_density.hip
Narrowing it down to avoid vex errors with a distance check, I still get the error :(
float dist = distance(@P, point(1, 'P', 0));
float d;
if(dist < chf('max_dist')){
    d = fit(dist, 0, chf('max_dist'), 1, 0);
    d = clamp(d, 0, 1);
    d = chramp('gamma', d);
    f@density = d;
}else{
    f@density = 0;
