how to lock or pin a point to a specified primitive and uv ?
8 hours ago, ryew said:
Unless your geometry topology will be changing across the framerange, any reason not to just use a rest position for the points as is typically done when sticking points to geo? (https://www.tokeru.com/cgwiki/index.php?title=Rest_Attrib)
hey Ryew !
thanks for the idea using rest sop.. checked the tokeru page. and tried out the rest sop. but looks like it only saves the world position ,
I need to lock the points on the surface geometry( like follicles in maya, they are like rivets on the surface constrained by u and v .
the rotate rest fails just when i move the points away from the origin and rotate it.
thanks for the reply !
Edited by carthick
typo
