evanrudefx Posted January 31, 2021 Share Posted January 31, 2021 (edited) Hello, I am trying to use the flipbook motion vector with an explosion exported from houdini using sidefx labs tools. I followed a couple tutorials and I am pretty sure I got the motion vector intensity setting right and everything else. But for some reason it is stuttering really badly. My explosion (in real time) is pretty fast moving. Maybe its moving too fast and it is only 24 frames a second? If you notice, toward the end of the flipbook, it starts to stop stuttering when the explosion is moving slower at the end. That's why I was wondering if its maybe I just need a slower explosion or just a higher frame rate atlas, like 60 instead of 24. Has anyone gotten the sidefx labs motion vectors to work? Any thoughts? Edited January 31, 2021 by ejr32123 Quote Link to comment Share on other sites More sharing options...
Atom Posted February 1, 2021 Share Posted February 1, 2021 (edited) That does look like an FPS mis-match. You might want to try kicking out your explosion at 30fps. I faced something similar when I tried to supply a 24fps point cache as a Niagara source. I was told Niagara runs at 30fps. Try searching under Unreal project settings. You might be be able to adjust the engine playback speed and avoid reexporting your explosion. Edited February 1, 2021 by Atom 1 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted February 1, 2021 Author Share Posted February 1, 2021 (edited) imma try that out thanks! but its not in niagra, just a material edit: yea, thats not the problem. Edited February 1, 2021 by ejr32123 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted February 28, 2021 Share Posted February 28, 2021 (edited) Have you tried an 8x8 atlas? Or is that a 7x6 atlas but your columns/rows are 7? Did you render with pad power of 2 and have that in your ue4 image? Edited February 28, 2021 by HM_2020 Quote Link to comment Share on other sites More sharing options...
