POP Force Mass Remap
dubCUT
Hello Everyone
I noticed that many parameters have a "Use VEXpressions" checkbox and i try to understand them.
In my example i would like to remap the mass of the pieces by VEX. Preferably using a Ramp! And all that inside the local VEX of the POP Force :-)
So that there is a better distribution of pieces in Y.
I can't make it work... should it?
Use vexpression is used to dynamically adjust one or more parameters you see in the node, NOT updating point attribute individually. To do the later use pop wrangle/ geometry wrangle.
To use vex in pop force you can enable the top vexpression and use something like this:
force *= fit(@P.x, -2,2,.5,2);
those particles on one side will have half the force settings and on the other will have twice the strength
