Shift Array Vex
sadboy
How can I shift values in an array using a for loop?
For example: [0,0,0,1,1,1]->[1,0,0,0,1,1]
I would think that this code would work but it does not. Any help would be appreciated.
for(int j = 0; j < 6; j++ ){
    if(@new_tile_array[@new_prim_id] == 1){
        break;
    } else{
        int popped = pop(@new_tile_array);
        append(@new_tile_array,popped);
Edited by sadboy
forgot to add a line of code
Another option:
If you need to create wrapping behaviour and want to avoid a loop, with modulus you can create "wrapping" behaviour.
Essentially split the  array in two and swap the start and end. What defines the offset is where you put the split.
int a[] = array(0,1,2,3,4,5,6);
int i = len(a);
// offset value
int offset = 1;
int out[] = a[offset%i:i+1];
append(out,a[0:offset%i]);
i[]@out = out;
Edited by snoot
