bobbybob Posted March 5, 2021 Share Posted March 5, 2021 Hi Is there a way to keep the original point numbers when using polyextrude? Quote Link to comment Share on other sites More sharing options...
bobbybob Posted March 5, 2021 Author Share Posted March 5, 2021 (edited) Deleted, not correct... Edited March 5, 2021 by bobbybob Quote Link to comment Share on other sites More sharing options...
anim Posted March 5, 2021 Share Posted March 5, 2021 Can you use Peak SOP? 1 Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted March 7, 2021 Share Posted March 7, 2021 On 3/5/2021 at 9:26 PM, bobbybob said: Hi Is there a way to keep the original point numbers when using polyextrude? Match Topology SOP will fix this 1 Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted March 7, 2021 Share Posted March 7, 2021 You can also store the ptnum as (extra)attribute before extrude. Extrude will transfer this attribute to the new points, which can be used to sort the points. 1 Quote Link to comment Share on other sites More sharing options...
