william-or Posted March 8, 2021 Share Posted March 8, 2021 Hi everybody, Can anyone tell me why in a solver, if I run over points with a wrangle and I set an attribute to, for example, point 15, when I reach another point down the line and i check for the attribute value of point 15 the value is not updated? It only updates once the wrangle is completed and it moves to another node down the stream. I'm trying to move points considering other points attributes but I can't find a reliable way of doing that without having out of date attributes. Quote Link to comment Share on other sites More sharing options...
Skybar Posted March 9, 2021 Share Posted March 9, 2021 Hard to help without seeing what you are doing, but yes, attributes are only written and geometry is only created at the end of a wrangle after the code has been run. Quote Link to comment Share on other sites More sharing options...
underscoreus Posted March 16, 2021 Share Posted March 16, 2021 Might be unrelated, but from my experience, be careful about looking at attributes inside a SOP Solver. Attributes and viewport previews can be wonky in there. It's always safer to look at the output of a solver in SOPS. 1 Quote Link to comment Share on other sites More sharing options...
