Rotation in Wirecaptures
Hi, the wire capture and wire deform are not taking the rotation of the points to rotate the geometry, attaching the sample scene file below,
Basically, I'm rotating the curve and deforming the geometry using wire capture and deformer but it's just moving leaving the rotation
Thank You
wirecapture rotation.hip
Thank You
Hi, you have to connect transform1 to timeshift1 instead of bend1 to timeshift1, right now on frame 1 wire capture sop captures to already curved primitive. And play with 'Blending' parameter on a wire deform sop.
