Max_Steven Posted March 14, 2021 Share Posted March 14, 2021 Hello, I need to modeling this square bottom bottle. I know there is the boolean node but it's not clean and can't be bevel afterward If you have any idea please help me Thanks Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted March 14, 2021 Share Posted March 14, 2021 Hi, you can sweep with different cross sections for example. bottle_sweep.hipnc 2 Quote Link to comment Share on other sites More sharing options...
Max_Steven Posted March 14, 2021 Author Share Posted March 14, 2021 On 3/14/2021 at 9:38 AM, Aizatulin said: Hi, you can sweep with different cross sections for example. bottle_sweep.hipncFetching info... Expand Wow so so much cleaner than I can expect Thank you so so much. I didnt thought I can create square from circle node ;)) Learned a lot from your generosity. Thank you Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 14, 2021 Share Posted March 14, 2021 (edited) Hi Max, first rule: do not boole. Boolean subtractions seem very intuitive at first glance, but if not used advisedly they can do a lot of harm to the mesh's topology. Instead, you could measure the direction of a cylinder's surface towards the profile curves and blend between their closest positions. > bottle.hipncFetching info... Edited March 14, 2021 by konstantin magnus 3 Quote Link to comment Share on other sites More sharing options...
Max_Steven Posted March 14, 2021 Author Share Posted March 14, 2021 On 3/14/2021 at 10:20 AM, konstantin magnus said: Hi Max, first rule: do not boole. Boolean subtractions seem very intuitive at first glance, but if not used advisedly they can do a lot of harm to the mesh's topology. Instead, you could measure the direction of a cylinder's surface towards the profile curves and blend between their closest positions. > bottle.hipncFetching info... Expand My Jaw just dropped to the floor 0.0 Yes i just thought there must be a way without using boolean How on earth you can come up with such those vex lines ;)) Btw, I just watched your tutorial about creating the shampoo bottle too Really thank for your help 1 Quote Link to comment Share on other sites More sharing options...
Max_Steven Posted March 14, 2021 Author Share Posted March 14, 2021 On 3/14/2021 at 10:20 AM, konstantin magnus said: Hi Max, first rule: do not boole. Boolean subtractions seem very intuitive at first glance, but if not used advisedly they can do a lot of harm to the mesh's topology. Instead, you could measure the direction of a cylinder's surface towards the profile curves and blend between their closest positions. > bottle.hipncFetching info... Expand Btw, I tried to tweak your setup but seems like the top part can't be cylinder tube. If I reduce the Tube column to get more cylinder shape tube then it will break the mesh and if I keep high column for the tube then it will be square tube not cylinder Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 14, 2021 Share Posted March 14, 2021 On 3/14/2021 at 10:38 AM, Max_Steven said: seems like the top part can't be cylinder tube. Expand If you want the top to be perfectly round, just scale the grid to 0 and control its radius with the offset in the attribute wrangle. Quote Link to comment Share on other sites More sharing options...
Max_Steven Posted March 14, 2021 Author Share Posted March 14, 2021 On 3/14/2021 at 10:44 AM, konstantin magnus said: If you want the top to be perfectly round, just scale the grid to 0 and control its radius with the offset in the attribute wrangle. Expand Oh yeah it's true With 1 grid scale to 0 I can have top part cylinder and bottom square Amazing ;D Thank you Quote Link to comment Share on other sites More sharing options...
