Houdini 18.5 Group by Attribute
Hello there,
Before in Houdini GamDev has a sop called group by attribute.
So if I use name node to group primitives, pack them  then just  use the group by attribute node Houdini will recreate all the group based on the name attribute I had
In Houdini 18.5 it has a node called group from attribute boundary which does similar thing but I can't figure how to set it up so it can auto create group based on name not manually set up each name like in the photo
I hope I explained it well.
Thank you for reading this
