Vellum Weld freezes Houdini if using voronoi fracture
ianoreo
Hi there!
For some reason the vellum weld node completely freezes houdini if I'm using a voronoi fracture (interior surfaces disabled) to split up my cloth before sim. Edge fractures seem to work fine. It seems the "add bend constraints" vop within the Vellum Weld node is the culprit (or at least what's causing the snag).
Is there anything I can do to prep the geo before going into Vellum that will fix this? I quite prefer the look of the voronoi fracture compared to what edge fracture produces. Voronoi fracture does work on super low-poly inputs but anything at the level that I'm working with (100k+) is completely freezing the software.
Thanks!
Edit: Adding a project file here as an example
Vellum_VoronoiWeldExample.hipnc
Edited by ianoreo
adding project file
