vellum - it is posible to delete softbodies over time?
dyei nightmare
just wondering if its posible to delete vellum soft bodies over time,  i kinda suspect that when you delete geometry before creating the solid object, will explode or collapse, due the geometry changing,  and when you delete parts of the solid object is even worse,  so,  could it be posible in any way?
5 hours ago, ryew said:
Can you use the "patchname" attribute to assign each object a unique name you can use to delete that entire object when it is outside the frustrum instead of just a handful of points?
yes but the problem is that  using instances in this project is not easy, it is harder to sim with a handfull of items,  up to 50, thats why i used a single solid...   for some reason is faster
Edited by dyei nightmare
