Export spatial audio to wav file.
REC
ok so this file of yours is really cool! This is the first time I am working with spatial audio so it is a bit of a mystery to me. The answer might be in your file but I can't understand how this is set up "mind blow".  Is the "playback" where you save the audio file to a wav on disc ? I have attached my stripped-down file.
I want to export this and master the output in Ableton.....
I also can't hear the sound when I preview this to Mplay.
sorry for the 20 questions!
spital.zip
Preview you have option in MPLAY ..use panel audio settings to "link"download" file that you have exported from null IN Spatial ..
now you can make   anything  Folly effects ...imagination Olalaa ..Do you hear a difference ?
You need only now to play with position and its your option what you want..
Plus I recommend  to read and Download music tools
Have Fun ..Please post your experiments :)
las.wav
test_audio_05_stripFix.hiplc
las.wav
Got it thanks! Yes, the Houdini toolset looks really good. I have gone through all the videos on his Vimeo page a few times.
Ideally creating all the audio in Houdini would be where I would like to get to. (procedural audio)
for now, I am just placing sounds I have made in 3d space and linking to frequencies, and using displacement....... see my test below.
https://drive.google.com/file/d/1I8D0JyV77IIvjspxNEhXzEUeCAnUAI3o/view?usp=sharing
test_frames.mp4
Edited by REC
