Gradient Posted December 12, 2002 Share Posted December 12, 2002 I'm new to houdini so this may be easily solved I want to make a shader that is like a green goo sort of like flubber ie) if anyone can give me a general idea how to do it in the Vex Builder I would appreciate it. Quote Link to comment Share on other sites More sharing options...
Jason Posted December 13, 2002 Share Posted December 13, 2002 I'd definately start with the Glass VOP. Quote Link to comment Share on other sites More sharing options...
Gradient Posted December 13, 2002 Author Share Posted December 13, 2002 Yeah I'll try that, but im going for like a moist jello look y'know? any more tips would be appreciated *thanks for the reply jason * Quote Link to comment Share on other sites More sharing options...
AndrewVK Posted December 13, 2002 Share Posted December 13, 2002 You can make the transparency dependable on the distance the ray traveled from P to the first collision. "float rayhittest(vector P, D; float bias, [scope]) float rayhittest(vector P, D; vector &pHit, &nHit; float bias, [scope]) This function will send a ray from the position P along the direction specified by the direction D. The length of the D vector represents the farthest distance considered when check for occlusion. The function will return the distance to the object intersected. If no object is hit, the distance will less than 0. If pHit and nHit are specified, they will be set to the position and normal of the hit surface." Quote Link to comment Share on other sites More sharing options...
MG Posted December 13, 2002 Share Posted December 13, 2002 Making a shader that mimicks the "Flubber"-look? Sounds very interesting! Quote Link to comment Share on other sites More sharing options...
Gradient Posted December 14, 2002 Author Share Posted December 14, 2002 So far this is what I have, but it's not what I'm going for I wanted to know if there is a way to add layers. The first layer would be the bubbles inside the flubber, second the color and transparency and, the third layer would be a moist film around it. Any help is appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
MG Posted December 14, 2002 Share Posted December 14, 2002 Wow! Looks pretty nice. And how long did that take to render? Quote Link to comment Share on other sites More sharing options...
Carlos Posted December 18, 2002 Share Posted December 18, 2002 Well, this is probably as far as I will get with it =) Not flubber, but interesting no? :? --Carlos Quote Link to comment Share on other sites More sharing options...
MG Posted December 18, 2002 Share Posted December 18, 2002 Very nice there Carlos! But, do make him more transparant next time. Or at least, whatever it takes to simulate the nice translucent look of the original Flubber. By the way, the figure itself looks almost identical from this angle! Quote Link to comment Share on other sites More sharing options...
Carlos Posted December 18, 2002 Share Posted December 18, 2002 Thanks I was playing with layering, could not figure out how that works... I figured, if I set one of the shading layer parameters to layer attribute 1 and the other to 2, that it would work that way.. but it does not.. I am connecting the layer parameters to the surface position 'P' ... Hah! .. it's my most complex model yet! =) --Carlos Quote Link to comment Share on other sites More sharing options...
stu Posted December 30, 2002 Share Posted December 30, 2002 I was bored so I played for a bit. It's kinda rough (I was too lazy to make the shadow filter the green colour, etc.) but you get the idea. stu Quote Link to comment Share on other sites More sharing options...
Gradient Posted January 1, 2003 Author Share Posted January 1, 2003 Hey stu mind sharing the file with me, so far yours is the closest to what I want If not that's cool, I can respect that. Quote Link to comment Share on other sites More sharing options...
