How to python rename node in subnet
Morrorz
I have Subnet node name is "subnet1".
In "subnet1" i have ROP node.The same name as subnet is "subnet1".
When i change my subnet name change the my ROP name too.
How to write in "On Name Change" python ?
Thank you.
Edited by Morrorz
I typed this (the example provided in the link I sent) in the Python Shell and it works fine :
def name_changed(node, event_type, **kwargs):
     print("Geo node is now named %s" % node.name())
hou.node("/obj/geo1").addEventCallback((hou.nodeEventType.NameChanged, ), name_changed)
You have to define a function to link to the event callback, and no just copy one line... Note this will work only for the current session, it won't be saved in the file if you close Houdini (as written in the doc link).
Cheers,
