anbt Posted April 29, 2021 Share Posted April 29, 2021 Guys, how come I don't see through the bubbly fluid on top? The bottom orange fluid is in a separate object, rendered normally and the one on top is within a separate object as well, rendered as particles. The bubbly material has transparency 100%, how come I don't see what is behind? Thank you !! Quote Link to comment Share on other sites More sharing options...
Sepu Posted April 29, 2021 Share Posted April 29, 2021 What render engine is this? Quote Link to comment Share on other sites More sharing options...
anbt Posted April 29, 2021 Author Share Posted April 29, 2021 Redshift Quote Link to comment Share on other sites More sharing options...
Sepu Posted April 29, 2021 Share Posted April 29, 2021 Depending on what version of RS are you using, you might have to enable this guy on the system tab. If that doesn't work, the best thing is sharing a .hip file. Quote Link to comment Share on other sites More sharing options...
anbt Posted April 29, 2021 Author Share Posted April 29, 2021 I tried but it didn't work. Here's the hip. Thank you RS_issue.hip Quote Link to comment Share on other sites More sharing options...
Sepu Posted April 29, 2021 Share Posted April 29, 2021 Is working fine here I can see through. I do not have the red fluid that you have but it should work, the only thing that I noticed is that you didn't have a redshift material applied to the red fluid geo. RS Version 3.0.44 Quote Link to comment Share on other sites More sharing options...
anbt Posted April 30, 2021 Author Share Posted April 30, 2021 there is the material now and it still doesn't work as in your example. really don't get why. I have cached one frame of each fluid. You should see it now. Still not transparent Thanks RS_issue.hip Quote Link to comment Share on other sites More sharing options...
anbt Posted April 30, 2021 Author Share Posted April 30, 2021 this helped but I feel like this is not the way, my render time will explode! Quote Link to comment Share on other sites More sharing options...
