Rbd objects emit particles
papsphilip
i have some cubes that fall to the ground. I am trying to emit particles at the same time from the front side of each cube creating noodles that collide with the cubes.
i thought the multisolver might come in handy but its not working so far. First time i am using it.
Essentially i am trying to replicate grain emitted noodles on cgwiki
https://www.tokeru.com/cgwiki/index.php?title=HoudiniDops#Grain_emitted_noodles
but my source is an rbd object.
i am not sure if this is possible.
test.hip
So far the only way i found was to separate the RBD sim from the pop sim. so first the cubes fall, then using the result from the sim i emit particles turn them to noodles and they get to collide with the cubes but they do not push them around or anything.
Here is my progress so far
test_sim2.hip
