betty Posted December 13, 2002 Share Posted December 13, 2002 hi everybody well i had left the character tools alone for quite a while until the recent post on bone setups got me excited again. i tried doing a simple walk cycle but am having problems. i am not rally worried about the animation, (actually it's quite incomplete and simple and not the priority or focus of the excercise), but i am having difficulty with organising the CHOP networks into a simple streamlined workflow. what i really want is say all th parameters which are going out to specified channels to all come out of one CHOP. i then figure it would then be easier to do things like blends from walk>run , run>jump etc. basically just making things easy in the workflow then having all these different CHOPs everywhere. i've attached a hipfile, which may be of interest to "complete novices" as i am very much a novice myself, but i am hoping for some advice on how to better set this up for animation transitions. thanks kenny for the leg set-up which is pretty much (99%) what i've used. btw, i just remembered my cycleCHOP is a mess, i can't seem to keep my cycles in proportion. as i'm cycling the z-xform of the feet, one seems to be going fine while the other looses a bit of distance which each cycle which of course turns into a disaster. it seems simple enough and can't see why it is doing that to one channel and not the other. obviously i'm a touch confused......????? walkcycle.zip Quote Link to comment Share on other sites More sharing options...
danteA Posted December 13, 2002 Share Posted December 13, 2002 Hmm ... maybe it's because one of your cycle chops for the foot raising ihas Blend from Start to End turned on? The stretch chops also look a bit weird though ... maybe you should use cubic instead of linear for those. Finally, maybe you need to overlap the cycles by 1 frame? Quote Link to comment Share on other sites More sharing options...
betty Posted December 18, 2002 Author Share Posted December 18, 2002 thanks dante i'll have a look at it when i get back to the lab, haven't been there since i posted this in. i'll let ya know how i went with it. betty Quote Link to comment Share on other sites More sharing options...
betty Posted January 10, 2003 Author Share Posted January 10, 2003 finally had a chance to look at this again, been very busy!! mmmm, i barely remember it.....it looks like a mess......i'll try again as i've time on my hands now and i'll post back with the results. b Quote Link to comment Share on other sites More sharing options...
Jason Posted January 13, 2003 Share Posted January 13, 2003 What's up, betty? What's been keeping you so busy? I'd love to know what people are busy doing with Houdini nowadays. Me and the small team I'm in are busy with fluid simulation tasks for "The Day After Tomorrow" (or it might be just called "Tomorrow" now).. writing SOPs to interface with our fluid simulation software, reading and writing vectorfields, surfaces, levelsets, and coming up with particle and volume rendering techniques. We're still in development but it's getting more and more fun every day as the system get solid. Cheers, J Quote Link to comment Share on other sites More sharing options...
