venxm Posted May 26, 2021 Share Posted May 26, 2021 (edited) Hello, I'm brand new to Houdini and have been working on a "shockwave" effect and I have just looked in the Render View and there was only black screen. Then I tried to actually render it but it would still only show a black screen. I've attached some images below to show the issues that I'm having. This is my Network inside of a Geometry. This is how it looks inside Scene View. This is how it looks in the Render / Render View. Here's the project file. Please help me out if you can learning shockwave.hipFetching info... Thank you. Edited May 26, 2021 by venxm Quote Link to comment Share on other sites More sharing options...
haggi Posted May 27, 2021 Share Posted May 27, 2021 Well, since your smoke color is black and you do not have any temperature in your temperature field or in the flame field, the result becomes black. If you do not need the temperature or flame you can simply set the smoke color in the pyrosolver sop node. Quote Link to comment Share on other sites More sharing options...
venxm Posted May 27, 2021 Author Share Posted May 27, 2021 On 5/27/2021 at 7:12 AM, haggi said: Well, since your smoke color is black and you do not have any temperature in your temperature field or in the flame field, the result becomes black. If you do not need the temperature or flame you can simply set the smoke color in the pyrosolver sop node. Expand Thats what I thought I had done. I went into the pyrosolver, then under the "Look" tab & set the smoke to black. I wasnt sure if there was anything else to do. And I'm not quite sure what you mean by no temperature in the temperature field or flame field. Quote Link to comment Share on other sites More sharing options...
haggi Posted July 6, 2021 Share Posted July 6, 2021 Sorry for the late reply, I didn't see your answer. If you create a pyro sop solver and have a look at the sourcing, you see that it has an "burn" and "flame" input. The new pyro solver works in a way that it uses a scalar field called "flame" to create temperature, smoke and expansion. And you can add temperature as well. But in your setup, you do not have an flame input and and no temperature input because you do not have a temperature scalar field or flame scalar field in your inputs. Quote Link to comment Share on other sites More sharing options...
